Browse Forums General Discussion 1 Jul 11, 2013 8:35 am What is the correct protocol for negotiating deduction on price after having a Building and Pest inspection that has identified several significant concerns? Should we simply ballpark a lower figure as our new offer, or go to the extent of getting quotes for each repair that is required and use that as our basis for renegotiation? What the best approach here? Re: Negotiating deductions after B+P inspection? 2Jul 12, 2013 8:38 am Depends of the extent of the damage. Getting quotes to use as a negotiation I think would be pointless. Chances are the seller would just say they can get it done for cheaper, or think (probably correctly so) that you purposely got high quotes. If you can find someone that wants to quote it, great, the more information you have the better you can make a realistic offer. Getting quotes would be a good idea if there is extensive damage and you are not familiar with what would be involved to repair the damage. But that would be used purely as your information to make an offer. If it's small stuff, talk with the inspector, he may have a better idea of costs, and then list the defects when making your offer. Just be aware that not all inspectors are good. Some can miss major defects, so if there is already signs of damage there may be more that he missed. Re: Negotiating deductions after B+P inspection? 3Jul 14, 2013 2:10 pm You dont have to justify yourself to the vendor about what you want to pay. A property is only worth what a particular buyer thinks it is worth at a point in time.Your B & P inspection is instrumental in your perception of its worth. Simply inform the agent you've had a -ve report, supply a copy of the report if he wishes to see it (its part of the REIQ contract conditions in qld), and make your amended offer. The Vendor can like it or lump it, or choose to negotiate with you. you need to understand the breakdown of warranties. 90 warranty is considered as minor defects rectification period where as the longer ones are more major/structural… 1 5290 The significant date is when receive final payment invoice Check that section of contract Bit of fluff by builders prior to that 1 15836 i would suggest nothing is unreasonable for PCI. we did all sorts, including checking the hot water, checking all the GPO's had power, testing that the showers were… 9 98548 |
