Browse Forums General Discussion 1 Jul 10, 2013 7:34 am I have to join a piece of powdercoated aluminium with a hard plaster wall that has been painted. Some paint has come off, so it may be a combination of paint and plaster. It is the inside of a window frame. I am able to make up some timber pieces to clamp it if required. What is the best adhesive to use? Thanks. Re: Adhesive to connect aluminium with paint/plaster 2Jul 10, 2013 8:27 am Not sure where or how you need to do this, but silicone or Sikaflex would be the way to go. Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 I’m restoring all my 40yr old windows and I want to install seals around the casements. I’ve sanded back and oiled the frames with sikkens. My plan is to box up inside… 0 6651 Hi, I'm clearing the tiles from our horrid 50 year old bathroom and preparing to lay new ones. Bugger of a job getting the old… 0 8210 Hi, Have used the Dulux 1 step, oil base on my walls(white set), out of can it’s already a more thinner product than a final coat paint Also in water base Water or… 3 5197 |
