Browse Forums General Discussion 1 Jul 05, 2013 3:47 pm Got a couple of roof penetrations in our low pitch roof. Water's getting in. There are weather seals but they might not have been installed correctly because they are covered in what I think is a silicon/polyurethane sealant. Is that normal? The sealant looks pretty old and is starting to perish. The house is only 7 years old. Gutters cleaned regularly. Can anyone recommend a good sealant to use for a medium term repair, or should I just look at replacing the weather seals completly? Could this be a building defect? Any comment would be appreciated. Reuben DIY, Home Maintenance & Repair Hi, I've got a brand new (2nd hand) Bosch Hydropower 16H tankless hot water heater. Since it was installed I have noticed it leaks a lot. I took the cover off and it looks… 0 24140 Hey guys, what’s everyone opinion on James Hardie linea direct fix to frame? Would this be the most common method and anybody ever had any problems down the track? 0 5132 DIY, Home Maintenance & Repair If the railhead is so poorly fixed it is also likely that the railhead is also non compliant, what about overflows and sealing railhead to the gutters?. 3 5963 |
