Browse Forums General Discussion 1 Jun 30, 2013 2:08 pm I wanted to attach a dryer off the ground to a sandstone wall. I was wondering if there were any options beyond drilling holes/attaching with bolts to secure it to the wall? The rock appears to be very hard and so I will have trouble drilling the holes, there is also electrical circuitry behind it which I am trying to steer well clear of and so I was wondering if there are other options? Re: Attaching a dryer to a wall 2Jun 30, 2013 5:02 pm Quote: The rock appears to be very hard If it is sandstone it wont be 'very hard' and I doubt there are other options Arfur Re: Attaching a dryer to a wall 3Jun 30, 2013 5:32 pm We attached ours to a wall made of concrete bricks, just used a normal drill with a masonry bit and some anchors. Five years later with the dryer being used 3-4 times a week and its fine. - MrsT Brought first house in 2008. Renovated...a LOT. Built in 2013. Our thread: viewtopic.php?f=31&t=67954 Re: Attaching a dryer to a wall 6Jul 01, 2013 7:59 am You need to use a masonry bit in a hammer drill ( which is what Danois means ) or an ordinary electric drill that you can switch to hammer drill mode. And as per what Uncle Arfur said sandstone is a relatively soft rock. Stewie Re: Attaching a dryer to a wall 7Jul 01, 2013 8:29 am Stewie D You need to use a masonry bit in a hammer drill ( which is what Danois means ) or an ordinary electric drill that you can switch to hammer drill mode. Yes, that is exactly what I meant! I didn't know it was called a hammer drill in English (it is in Danish, but rarely does compound words in Danish translate directly into English). Re: Attaching a dryer to a wall 8Jul 01, 2013 12:07 pm D101 I wanted to attach a dryer off the ground to a sandstone wall. I was wondering if there were any options beyond drilling holes/attaching with bolts to secure it to the wall? The only way I think without drilling holes into the sandstone would be to secure a timber frame from the ceiling to the floor/bench and mount it onto the timber. DIY, Home Maintenance & Repair Follow up question - any ideas on how to set up a portable air conditioner through this kind of window? 1 6230 I plan on installing an undercover walkway (awning ??) from my carport to the back door as shown in sketch. I will be using Boxspan Beams and have no concerns regarding… 0 707 Thank you again Simeon.. I will call my certifier for that. Have a good day 4 5144 |
