Browse Forums General Discussion 1 Jun 27, 2013 7:40 pm We have been in our Beechwood home for about 6 months now, and since the weather has been crappy here in Newcastle our water isn't very hot and since its winter I do like a nice hot shower of a night and morning. The problem is, that we do have gas boosted solar but I cant seem to figure out how to turn on the booster???? we have a blank switch in our ensuite and I am thinking that this could be the switch, but I am unsure on how to tell if it is either on or off ... is there anyway of telling??? Re: No hot water in a new Beechwood Home 3Jun 29, 2013 12:41 pm When you turn you hot water on full you should be able to go to the gass booster and hear the gas burners fired up. If not, most use an electronic ignition to ignite the gass so check that it is plugged into a power point and switched on, also that the gas valve in on as well. Maybe some kids turned it off. Note : also there is a knob with a arrow on it that lets you adjust the tempeture. This just may need a turn. Re: No hot water in a new Beechwood Home 4Jul 08, 2013 7:37 pm Were you able to sort it out? We have solar HWS installed by BW too and our booster switch is in the laundry. Hopefully you were able to sort it out Built with Beechwood Homes 2011. LakeView Lodge with Triple garage Building with Beachwood again 2013. Merlot with guest (investment) the sun master is the solar heating to "warm" the water in the tank the S26 is your hot water system which will heat the water (25 degrees?) so with both turned on you… 2 13370 I want to build a decking to the drawn shape outlined in black. The problem is how close can I build to the gas hot water unit? Will I be able to build around it and be… 0 20224 DIY, Home Maintenance & Repair Hi, I've got a brand new (2nd hand) Bosch Hydropower 16H tankless hot water heater. Since it was installed I have noticed it leaks a lot. I took the cover off and it looks… 0 24146 |
