Browse Forums General Discussion 1 Jun 25, 2013 5:51 pm Hello everyone. I have a 1.2m x 1.0m space in my washroom and I would like to put in a sort of "ghetto pool" instead of a normal bathtub. Primary reason is because I would like to put something in that is portable so that when I eventually move out I don't have to basically give away the tub as a "gift" to the next person living there. It would act basically like a normal bathtub in that it has a drain out the bottom... hot/cold water would be supplied by a nearby showerhead / faucet so that's not required to be built in. Also, I live in Korea so the washroom is built so that the entire room drains water down a single drain in the center.. no need for any fancy draining just let the water out and everything should be fine. I was going to just buy an inflatable or framed outdoor pool but they are all so huge. Unless someone knows of a nice small <1.2m x 1m pool perhaps I will have to somehow build it custom? Ideal dimensions would be 1.2 m wide x 1.0 m long x 1 m high (a bit high vertically but then I should be able to stretch out a bit.^^) Any thoughts on how I might accomplish this? Thank you so much for reading all. Re: Indoor "Ghetto pool" what are my options? 2Jun 25, 2013 7:53 pm These would be good but about $11k AUD don't know if you could get it sent to Korea, but they do come from the states http://www.endlesspools.com/waterwell.php Re: Indoor "Ghetto pool" what are my options? 3Jun 25, 2013 10:02 pm Hmm, well the size is sort of correct in the vertical... I cannot imagine spending $11,000 for a 1 m x 1 m pool O_O. Also.. trying to get something together that basically just holds water and drains it... heater/etc.. is not needed because this is going to be acting as basically a deep bathtub. Any other thoughts? Edit** It also seems to be twice the size I have available... max length 4 feet max width 3.5 feet.. might be able to push the length out to 5.5 feet depending on the height. Re: Indoor "Ghetto pool" what are my options? 4Jun 29, 2013 2:50 am Here is an example of a finished product that is very similar to what I want to build.. except with incorrect sizes and no way to disassemble: http://www.doityourself.com/forum/attac ... athtub.jpg 0 4707 thanks. the above one is white Mat tiles and have gripness so going for this Mat tiles for both indoor and outdoor. Beaumont told it can be used in both indoor and… 2 1676 Standard uninsulated double brick has an R value of around 0.7. An insulated standard 90mm stud timber frame can have an R value of around 2.7. Even if you insulate a… 17 12050 |
