Browse Forums General Discussion Re: Who is responsible for water getting in our roof space? 4Jun 23, 2013 5:57 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Who is responsible for water getting in our roof space? 6Jun 23, 2013 7:10 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Who is responsible for water getting in our roof space? 9Jun 24, 2013 8:32 am Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Who is responsible for water getting in our roof space? 10Jul 05, 2013 2:46 pm Antenna Direct Perth www.antennadirect.com.au 0423919037 Get your home NBN Ready Smart Wiring and Structured Cabling in Perth Antenna Installations | TV Wall Mounting | Data Cabling HD Security Camera Systems / CCTV Re: Who is responsible for water getting in our roof space? 14May 21, 2020 9:51 pm
Re: Who is responsible for water getting in our roof space? 15Aug 04, 2020 10:04 pm
Re: Who is responsible for water getting in our roof space? 16Aug 04, 2020 10:21 pm victoriamorgon08
This is an old thread but I can update you on what happened. There wasn’t enough down pipes put in the area causing the gutters to back up and overflow back into the alfresco ceiling space. It was more than just wear and tear. There was pools of water in the ceiling causing it to fall down.i don’t think you’d expect that from any new roof. Re: Who is responsible for water getting in our roof space? 17Aug 04, 2020 11:01 pm So.....it was the gutters flowing back into the ceiling. I think that gutters still had to be fitted with an emergency overflow provision back in 2010. It also sounds like non compliance with the hf calculated height that I mentioned in my first post. Still see this even today. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. This certainly doesn't look good. I would be engaging with an independent inspector to have a look at this. As for the unscheduled site visits, most builders are quite… 1 28320 You can really use anything you want the main consideration would be how it looks once painted/finished - or the look you want. Cabinetmakers use MDF because its cheap… 2 9960 Cupcake.girl This really depends on your local council. Each one has different definitions and ways to calculate contributions. This is called a contribution… 1 3582 |
