Browse Forums General Discussion Re: No tiles under stairs? Is this normal? 10Jun 16, 2013 8:52 am This is probably a problem with the documentation. The ground floor plan should have been drawn with the lower part of the stairs shown and part of the under stair space shown where the floor covering should have been indicated. If nothing was indicated on the floor then no tiles. So check the drawings and specification where extent should be indicated. Do you have solar on the roof, because if its not a laying defect it looks almost like someone has been walking all over the roof in the mid section of the tile (weakest… 2 1935 looks experimental to me, reinforced screed would be a better option or even better insulate between ground and structural slab. I would not put granite over that,… 3 4998 You will need to replace the entire stairs. Carpenter is the trade you're after. 1 4342 |
