Browse Forums General Discussion 1 Jun 06, 2013 7:42 am Hi All, Been in my new home for 1 month now and noticing over time that the ceiling has lines across it. Initial thoughts are that its the ceiling joint shrinking and show the imperfections. It shows up on certain light condition and when I switch on the light. Is this normal? should this be a defect because of bad workmanship? and how hard is it to resolve?? Also its all over the house. Re: New Home - Ceiling plaster joint lines 2Jun 06, 2013 10:16 am 4mm is the tolerance for plaster joins. Unfortunatly cross light at certain times of the day doesnt help the joins from not appearing. Re: New Home - Ceiling plaster joint lines 3Jun 06, 2013 10:21 am It's been asked before. viewtopic.php?f=31&t=63247 Think most builds have it and some are worse than others. Not much you can do about it except try and hide it with some lighting tricks. Building with Jandson Homes - Eclipse 18. http://adgnetworks.blogspot.com/ Our 6m high Cathedral ceiling has 0 insulation, just plaster, wrap and tiles as far as I can tell. Wife likes the exposed beams, I hate the $600 per month heating bill,… 0 13494 To my understanding early saw cuts are to control shrinkage cracks, so doing them now would be pointless. Control joints may reduce ugly cracking during periods of soil… 3 9863 Hi all I need a guidance on how far I need to space expansion joints in the concrete driveway and its type (keyway/foam.) Contraction joints are at 3m max for a 125 slab. Thanks 0 10947 |
