We are considering moving our rangehood up by about 8cm, it's just the standard Westinghouse canopy rangehood that came free with our new home. We want to shift it up for 2 reasons, we keep smacking our heads into the corner of it and we also want it he same height as our window (ard to explain but its so our splash back fits in nicely) anyway, just wondering if anyone has moved their rangehood before and is it easy? On quick inspection it looks like you just unscrew a few screws and push it up a little.
easy- undo the screws either side of the lower part of the flue shroud and remove, push up the flue,the canopy part will just unhook of wall bracket when you lift it, raise up and rescrew bracket, and refit.Around a 30 minute job.
Just make sure that when you raise it it doesn't affect the efficiency.
Hello everyone,
I have a question regarding moving a chandelier after it has been mounted. The chandelier in question is quite large, measuring 4 meters…
