Browse Forums General Discussion 1 Jun 03, 2013 6:42 pm Hi all, my homes roof is timber, i believe its called shingles or shakes im not 100% sure. Anyway its leaking worse and worse and in desperate need of attention before winter really sets in, however i'm not sure who does this type of work? I know its going to be expensive to get this repaired as the entire roof will need to be replaced. Has anyone had any experiences with this type of roofing and knows of any contractors that do it? i've called several roof tiling businesses and none of them have even heard of this type of roofing. Thanks in advance Re: timber shingle/shake roofing 2Jun 04, 2013 10:29 am Well knowing where you live would be a big start ! Generally a shingle is made from sawn timber so the surface has a rough sawn effect. A Shake is generally from a split piece of timber and has a more natural texture. Either can be used for wall cladding or roof cladding. In Australia both tend to be made from Western Red Cedar. You need to google something like "Cedar Shingles Sydney" or "Cedar Shingles Melbourne" or wherever you live which will throw up a stack of links to suppliers or installers or both. Here is a bit of info too from Tilling Timbers as a downloadable pdf ... http://www.google.com.au/url?q=http://w ... B2l5C-W6RA Stewie I plan on installing an undercover walkway (awning ??) from my carport to the back door as shown in sketch. I will be using Boxspan Beams and have no concerns regarding… 0 787 Engineering timber is certainly a less fuss option, times cheaper to supply and install and better withstands humidity. 1 15990 Thanks Simon, I guess I'm no concerned with the volume of the noise rather that dead and hollow sound and feel that is associated with floating floors. But I'm not sure… 3 6192 |
