Browse Forums General Discussion 1 Jun 03, 2013 5:15 pm would really appreciate it if anyone can share their experience as to what to do on the following scenario. the property i bought was advertised as 3x2 with 1 x 1 self contained granny flat under same roof. even though it has a granny flat (with separate entry), it has been rented out as a whole house before only and therefore only have 1 power meter/gas meter installed. I plan to rent it out as 2 units to maximize rental income. Can anyone advise: 1. is it possible to request Western Power/Synergy to install a 2nd power meter to property? ( alinta also if anyone knows) 2. if possible, the steps and costs involved. is it very expensive? Thank you in advance. Re: help with cost for electric meter to granny flat 2Jun 14, 2013 1:12 pm But isn’t a 1x1 area too small? Who would want to rent in a small area like that? Re: help with cost for electric meter to granny flat 3Jun 14, 2013 2:03 pm Utility companies will not install a second meter for a single lot. You will need to install your own sub-meter, and then read this and work out the costs to each tenant. Any decent sparky and gasfitter can install the sub meters, however depending on how the existing cabling and pipework is configured, there could be some cost in splitting into two separate areas. I would suggest you simply go and talk to council about your proposal, most councils are getting onboard with ancillary dwellings. There is no benefit in keeping it… 1 4106 I think I know the answer but just checking to see if anyone has had experience with it. I want to build a small 20 square metre retreat in my backyard, it will have a… 0 13890 Any advice on how to ensure the kit home granny flat that im thinking of buying will get council approval. The kit home companys wont release plans without a deposit and… 0 7214 |
