Browse Forums General Discussion 1 Jun 03, 2013 4:06 pm Hi everyone, I'm in the early stages of having my house built and I am trying to source a copper cladding supplier in WA. I want to clad a feature wall in my house with this but am having a lot of difficulties locating one. If anyone knows anywhere it would much appreciated. Thanks Re: Copper Cladding???? 2Jun 04, 2013 10:41 am What kind of copper cladding - weatherboard style, flat sheet, beaten look ? Any decent sheet metal supplier would be able to get you raw sheets I'm sure. I've seen a couple of feature walls in commercial buildings and also a design centre a few years ago that had copper up on the walls. It looked pretty good too with a nice aged patina to it with a bit of that green discolouration thrown in for good measure. It looked like it had been on the wall for a couple of hundred years. Stewie Re: Copper Cladding???? 3Jun 04, 2013 11:36 am I believe there are artificial copper type wall finishes, used on the much older TV reno shows, which may be a whole lot cheaper and easier to accomplish Arfur Re: Copper Cladding???? 4Jun 04, 2013 1:35 pm Dulux make a couple in their metal effects range I think it is called plus some of the other paint makers put out a few faux metal finishes. Some of the looks are indistinguishable from the real McCoy but others look a tad "fake". I thought he was after the real deal. Stewie Re: Copper Cladding???? 5Sep 17, 2013 9:47 pm Hi trevor22, I'm in WA too and am also looking for somewhere that will do copper cladding on internal walls. Did you have any luck finding someone local? Nick DIY, Home Maintenance & Repair We have a hot water copper pipe that runs from our hot water unit on one side of our house under a concrete slab to our bathroom and laundry...old house so not ideal. The… 0 5115 Standard uninsulated double brick has an R value of around 0.7. An insulated standard 90mm stud timber frame can have an R value of around 2.7. Even if you insulate a… 17 12064 The spacing of the studs looks pretty large especially for a load bearing wall. 3 11122 |
