Browse Forums General Discussion 1 May 30, 2013 1:40 am Hi, completely new here. recently bought a property in Perth with r30 zoning. the land is 820sqm. I would ideally like to retain the front house and build at the back. Now, here is where i get really confused when i look at the R-Codes. under r30 says that minimum site area per dwelling is 270 and average 300. (now this sounds good because the available land behind + side access will total to about 310 sqm) however, it also says on next column that minimum lot area/rear battleaxe is 420sqm (not good at all because i wouldn't be able to build at back.) Can anyone please explain the following: 1. are all retain and build considered battleaxe? 2. when do we use the minimum site area as oppose to minimum lot area (i.e. if i choose survey strata will i be put under the 300 sqm average lot size requirement instead of the 420 sqm battleaxe requirement) have been told that we use battleaxe if want a green titled lot, is this correct? thanks very much for sharing your inputs. Re: are all retain and build classified as battleaxe 2May 30, 2013 5:52 am A battle axe block is only when the back block has its own driveway as the diagram in this link http://www.anewhouse.com.au/?p=2234. The other option for a retain and build is a strata title where there is a single access to two (or more) blocks and the driveway is then common property. The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: are all retain and build classified as battleaxe 3May 30, 2013 6:02 am With a battle axe block something like 50 or more sqm of the lot area is the driveway, which you may not have included in your calculations of lot area. The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: are all retain and build classified as battleaxe 4May 30, 2013 5:22 pm Yeah to give you an example, I actually bought a rear block last year to build on, essentially the "square part" of the block is 320 and the driveway is another 70sm. It is considered a strata but we requested sole use of the driveway which is now registered as such. Being a strata the amount of coverage, I think we couldn't build bigger than 200sqm falls into play whereas if it was green title I believe we could've built up to 250sqm although I can't exactly remember now. There are quite a few things to consider such as easements etc impacting where and how you can build too. https://forum.homeone.com.au/viewtopic.php?f=31&t=64434 Building our own custom design based on the Elwood by Dale Alcock Land settled - November Plans submitted to council - January Prestart - March Slab - 18 September Brickies - 23 October Re: are all retain and build classified as battleaxe 5May 31, 2013 7:04 pm bashworth A battle axe block is only when the back block has its own driveway as the diagram in this link http://www.anewhouse.com.au/?p=2234. The other option for a retain and build is a strata title where there is a single access to two (or more) blocks and the driveway is then common property. so if i choose the survey strata route then i would have satisfied the minimum lot requirements for a retain and build. won't be hard to make it so that front house and rear share same driveway (currently have 2 driveways) Thanks for the insight! My plot is a new development so hopefully I won't have too much problem during build as everyone should be roughly building together. I also… 2 3381 Thanks Draftroom that definitely helps a heap. We are still at the very early stage of planning to see what kind of house would fit on our plot. While we are on a… 3 15782 A question. Im in Queensland and building a new home. We managed to reach practical completion 6 weeks ago but we haven't heard any date for handover yet. Who should we… 0 5814 |
