Browse Forums General Discussion Re: Stay away from or not, PM me 2Apr 30, 2008 8:27 pm The problem you have in WA is that the industry in dominated by three big builders so there really isn't much choice. In fact, I think one bought one out so there are really only two. These are among the biggest builders in Australia and from recollection command 80% of the entire WA market.
The best way to check is from references, recent and a few years ago just to see how their product survives the long term etc. With the big builders over there, you won't have to go far to find a referree! Builders are people too.... Re: Stay away from or not, PM me 3May 02, 2008 11:29 pm hey there,
never lose sight of old tricks .... door knock!! always do you leg work, and ask people in the area you are moving into, who they used and the experience you had. The problem with the builders, is that they employ all these subbies, and as they change, the level of work changes as well. Ask, and you shall find! it's simple, but it works! Re: Stay away from or not, PM me 4May 02, 2008 11:32 pm ![]() hey there, never lose sight of old tricks .... door knock!! always do you leg work, and ask people in the area you are moving into, who they used and the experience you had. The problem with the builders, is that they employ all these subbies, and as they change, the level of work changes as well. Ask, and you shall find! it's simple, but it works! Good advice Thats how we found our builder ... saw a house being built with a facade we liked ... walked in and found our builder. And he recently changed his subbies and the quality of the work seems to be even better. I've got a challenge here. Background is the builder has cut too deep for the slab and the slab is now below the very substantial retaining wall. It's failed occupancy… 0 6828 ![]() DIY, Home Maintenance & Repair Are you in Australia? Did you import the tv? The reason I am asking is the Wi-Fi standards are slightly different, you may need to change the region settings on the tv. 1 8884 One of the things to be aware of is the contractual definition of the Owner. In the copy of the HIA standard I have the defination is: Owner' means the person,… 9 6235 ![]() |
