Browse Forums General Discussion 1 May 26, 2013 7:04 pm OOPS....found the page to post this on and finalised my shopping list as well. Hi, Just wondering if you have used a really good online lighting shop and you are really pleased with the product, could you please post the details? I have looked at Beacon in Hobart and just not happy as well as the lady being very pushy and judgmental!! Many thanks for your help. Re: Online Lighting Shops 2May 26, 2013 10:06 pm Building the Riva by Dale Alcock Homes. Follow our progress here: https://forum.homeone.com.au/viewtopic.php?t=57075 Re: Online Lighting Shops 3May 27, 2013 8:53 pm Seems a few people are raving about Prima Luce, some of there stuff is a bit wacky though. Not the typical online lighting store and worlds away from Beacon. I bought a couple of LED lights to test them before we buy some pendants, they should be here this week so will keep you posted. Building Standards; Getting It Right! 1. optional, you can but normally just use the earth from the main switch board 2. should be enough but the distance determines voltage drop - sparky should work it… 1 29070 I have a really long hallway which is 1100mm W x 11500mm L I would appreciate if anyone can give suggestions to light it up with Linear LED lights that goes from wall to… 0 9097 What? It's a lighting question, the control joint is only needed at 12m centres, a bulkhead or change of direction will suffice as a 'break' in the ceiling, just make… 8 8772 |
