Browse Forums General Discussion 1 May 18, 2013 11:42 am Just a quick question re BASIX (I did a search and there are thousands of posts about BASIX!!) - is it OK to upgrade things on your BASIX certificate after it has been issued? For example - if my certificate passed 3 star taps and I later decide to use 4 or 5 star (ie improvements) or if my windows stipulate single glaze and I later decide to use double glaze (same size and fabric but improved u-value) can I change them without notifying council or having a new BASIX certificate reissued?. Or are you locked into using what your certificate states? Re: Basic BASIX question 2May 18, 2013 12:00 pm waxinggibbous Just a quick question re BASIX (I did a search and there are thousands of posts about BASIX!!) - is it OK to upgrade things on your BASIX certificate after it has been issued? For example - if my certificate passed 3 star taps and I later decide to use 4 or 5 star (ie improvements) or if my windows stipulate single glaze and I later decide to use double glaze (same size and fabric but improved u-value) can I change them without notifying council or having a new BASIX certificate reissued?. Or are you locked into using what your certificate states? All sustainability, energy and acoustic reports are a minimum standard that must be achieved. You can increase the standard anywhere and use the same report/certificate, but you can't lower one area in compensation for increasing another without having the report redone. Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Basic BASIX question 3May 18, 2013 12:31 pm Thanks Ed - exactly the answer I wanted. My first run through the BASIX certificate gave me a really high 'pass' rating on things like taps, windows, water use etc. By tweaking a lot of of the details I was still able to attain a high pass rate but also give me a lot more flexibility when the time comes to actually deciding on, and ordering materials. I feel it is still a bit too early to lock myself down to certain products and materials. I will not want to lower any of the standards but in all likelihood will want to raise some now I have passed the BASIX report with a lot lower standards. Cheers - minds at ease now! You can really use anything you want the main consideration would be how it looks once painted/finished - or the look you want. Cabinetmakers use MDF because its cheap… 2 10075 I would say both styles you have pictured are steel. The lower chord of the first pic would be a massive lump if made using timber considering the size of the rafters. If… 1 6234 1 13206 |
