Browse Forums General Discussion Re: Has anyone rectified slab heave successfully 924Jan 18, 2019 7:03 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Has anyone rectified slab heave successfully 930Jan 21, 2019 9:47 am Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Has anyone rectified slab heave successfully 937Oct 19, 2019 11:24 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Has anyone rectified slab heave successfully 939Oct 20, 2019 10:40 am SaveH2O I have often wondered what would happen in the scenario where a builder didn't attend to site drainage (some are recidivists) and the new home owner had site moisture samples taken pre handover and the site was found to have high moisture levels in different areas next to the slab. Could that alter the site classification, arguably making a standard waffle slab under-engineered and thereby non compliant? A bit like buying a new car but driving away with retreads perhaps? Yes I can confirm this happens. For example if you have a class H2 site classification and the builder doesn't address site drainage during construction then the soil moisture levels can rise and the site becomes a class P(abnormal moisture conditions).If this happens then ground movement can exceed the designed ground movement for the slab and hence slab heave. The builder will usually say well this happened after hand over. Re: Has anyone rectified slab heave successfully 940Oct 20, 2019 2:38 pm insider Yes I can confirm this happens. For example if you have a class H2 site classification and the builder doesn't address site drainage during construction then the soil moisture levels can rise and the site becomes a class P(abnormal moisture conditions).If this happens then ground movement can exceed the designed ground movement for the slab and hence slab heave. The builder will usually say well this happened after hand over. Hi insider. Your reply is very interesting yet so obvious. Is there a maximum moisture content limit for a P class site? It also appears that some builders give scant attention to site drainage when a raft slab with piers is used. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Hi All, we are starting to think of building with Masterpiece Builders in Victoria, has anyone had any feedback or experience with them 0 13567 Hi we are looking to talk to people who have built with them recently. We have signed mid range built contract but identified that a lot of things are not included.… 0 645 I work with owner, he/she is my man on the ground and I instruct them when to visit the site and take photos and I have other tools in the bag. 4 15244 |
