Browse Forums General Discussion 1 May 06, 2013 12:39 am Hi guys - wondering if anyone can help me out. In Jan 2012 I got the place painted. It is a unit, but not an apartment - in the sense there is no one above or below me. 1950's unit, double blonde brick. Before the painting the place had a lot of cracking. Here is a photo of the cracking around the front door (it hadn't been painted in decades): Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ When I got it painted in Jan 2012 it looked as good as new. However, over time in the last few months, the cracking has to some extent reappeared: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Question is this: is this indicative that there is an issue with the foundations? There is a tree about 8 meters from my front door - is this likely to be the cause? If it is then this is important because then it become a body corporate issue. Any help or guidance would be appreciated Re: Cracking around front door after being painted 16 months 2May 06, 2013 6:06 am You would have to remove the paint and then assertain if there is cracking/movement underneath. Paint can crack like that if it is a thick coating when painted across wall and a metal frame door. From what I can see the door frame still looks square. (I can only see 1 image as looks like my work blocks the others.) Re: Cracking around front door after being painted 16 months 3May 06, 2013 10:27 am That is very common. In double brick houses the frames are bricked in. There is often a very small amount of movement in the frame. Over time from closing the door this movement allows the joints between the frame and wall to crack a little bit. The painter looks like he was fairly liberal with the no more gaps which doesn't help as when the crack forms it's often not along the edge of the quad but further out at the edge of where the no more gaps finishes. If the margins are still even around the door then nothing has moved, so it won't be a structural issue just cosmetic. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Cracking around front door after being painted 16 months 4May 06, 2013 10:40 pm chippy That is very common. In double brick houses the frames are bricked in. There is often a very small amount of movement in the frame. Over time from closing the door this movement allows the joints between the frame and wall to crack a little bit. The painter looks like he was fairly liberal with the no more gaps which doesn't help as when the crack forms it's often not along the edge of the quad but further out at the edge of where the no more gaps finishes. If the margins are still even around the door then nothing has moved, so it won't be a structural issue just cosmetic. OK, many thanks! That is reassuring! Just 2 questions: a)does this mean that anything can be done (using a better filler, etc) to give a more permanent solution? b) would your answer regarding whether it could be a structural problem change if I also mentioned that cracking between the wall and cornice has reappeared in the relevant area sorrounding the front door - though to be fair, even when just painted, you could see where the cracks had been filled in (a sign that they hadn't been properly filled in?) Before the painting: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Now: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Joe, it depends on your certifier but we are noticing the ones we deal with are really cracking down. So i would recommend you follow your approved landscaping plans to… 4 10982 My garage door has started playing up recently. Sometimes (and getting more frequent) when I press the button to open it, it wont. The motor is an ATA GD0-6V3. Red and… 0 2675 1 6637 |
