I am adding melamine shelving to my pantry and want to cover the fixing screw heads. I believe there is something called Melamine Dots,they are self adhesive. Does anyone know where I can pick these up in Perth Western Australia..?
Cheers
Browse Forums General Discussion 1 May 02, 2013 8:38 am I am adding melamine shelving to my pantry and want to cover the fixing screw heads. I believe there is something called Melamine Dots,they are self adhesive. Does anyone know where I can pick these up in Perth Western Australia..? Cheers Re: Melamine shelving 2May 02, 2013 9:42 am Galvins hardware. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Melamine shelving 4May 02, 2013 12:01 pm try screwing up from underneath into the shelf, the melamine dots fall off and start to lift. I think they look crap, especially in a pantry where cans etc will be dragged across. they honestly dont stick that great Re: Melamine shelving 5May 03, 2013 9:59 am The better ones are called head hole screws which as the name suggests have a hole about 5mm long x 1mm ø into which you push the little plastic cap which has a similar sized plastic shaft. Kitchen supply places have them but you probably have to buy them in lots of 1000 or more. We used to buy ours from Lincoln Sentry but I am unsure if they have an outlet near you. This mob here http://test.prodec.com.au/stemfix.html call theirs " Stemfix " but it is exactly the same type and also show a good diagram. Stewie Strong enough for what? For linen, absolutely. To climb on, no. I've got similar shelving in my garage and it holds a decent amount of weight. 900 wide shelves will carry… 1 4273 |
