Browse Forums General Discussion 1 Apr 29, 2013 12:41 pm I installed a steel security door. Easy enough. Unfortunately, because the security door and front door are only 15mm apart when closed, I cannot close both doors at the same time as the handles prevent this. I have a pic but cannot work out how to post to this topic. Re: Security door 3Apr 29, 2013 1:13 pm Thanks for replying JB1 I bought the security door second-hand, as by the measurements, it fitted perfectly. The security door sits inside a frame of 25mm x 38mm tube steel, which fits perfectly into the door frame. Re: Security door 6Apr 30, 2013 1:54 am Quote: the security door handle which protrudes 46mm and the gap between doors is only 15mm. I think the only alternative is to increase the gap between them by moving either one or both doors. You can get away with a Lockwood night-latch style of lock on the main door but Ive never seen a security door lock-handle with almost no protrusion. Or perhaps even customise the inside handle by removing it and welding a bit of flat steel to the lock shaft? But it wont look pretty Arfur Re: Security door 7May 05, 2013 8:59 pm I'm pretty sure the answer is you need a new door frame(Jamb,stop and all) 15mm between door faces? or 15mm between the front door handle and the security door screen? I suspect its between door faces and the only way to fix that is to replace the stop, but your frame might not be deep enough to take it if its only 15mm right now. You'll need to measure the jamb to figure out if its deep enough. I'd question whether or not its and external door frame also Hi When it rains in a particular direction water comes through the security door. It hits the main door and the bottom swells and jams. There is already a cover over the… 0 38448 It seems very clear to me that your contract states that a security account does NOT need to be established so the answer to the builder is NO. If in doubt find a contract… 1 8510 It's all about wireless, self install now. The cost/benefit of wired setups for the house are no longer what they used to be. Lots of wireless options. Eufy, Arlo and… 2 9797 |
