Browse Forums General Discussion 1 Apr 28, 2013 5:51 pm Heya we are looking at building a home in Perth on quite a steep block. We havent had much luck with the bigger builders due to the fall in the block. We are thinking of using a building broker - has anyone used one and any tips. Also any recommendations for builders who will build on a narrow sloping block? Cheers Re: Building Brokers 3Apr 30, 2013 9:36 am They also generally only do big and expensive builds but if that is what you are doing then go for it. I know if someone who said they saved thousands doing that. https://forum.homeone.com.au/viewtopic.php?f=31&t=64434 Building our own custom design based on the Elwood by Dale Alcock Land settled - November Plans submitted to council - January Prestart - March Slab - 18 September Brickies - 23 October go upvc window frames ensure insulation under colorbond. not just sarking, lighter color roof also not sure if you have seen this viewtopic.php?t=5823 last couple of pages… 4 111309 Even if it's not being sub-divided and you want to keep it as Torrens title, you will still need to talk to a town planner or Council themselves, to see if they will allow… 1 11388 |
