Browse Forums General Discussion Re: Flat roof tiles and imperfections 14May 29, 2013 8:43 am They have agreed to get the tile manufacturer to fix the loose valley tiles (which you can't really see very well in these photos) without any argument, but the ones that are kicked up here and there they say they won't, as it's within the tolerance for roof line undulation (20mm over 4000mm) in the Guide to Standards and Tolerances. However, in the Australian Standards document, this only specifies how much a roof batten is allowed to bow or spring; what it says about roof tiles themselves is that all courses must be aligned horizontally and vertically. I don't think meeting the spec. for batten alignment should get the builder out of meeting the spec. for tile alignment, and the manufacturer's installation documentation says that all courses must be aligned "to achieve the best look for the roof". I don't think that's "the best look for the roof". (I also have a thread in the standards section specifically about the relevant standards). I would suggest you simply go and talk to council about your proposal, most councils are getting onboard with ancillary dwellings. There is no benefit in keeping it… 1 4069 I think I know the answer but just checking to see if anyone has had experience with it. I want to build a small 20 square metre retreat in my backyard, it will have a… 0 13829 Any advice on how to ensure the kit home granny flat that im thinking of buying will get council approval. The kit home companys wont release plans without a deposit and… 0 7114 |
