Browse Forums General Discussion 1 Apr 25, 2013 2:45 pm Just wondering if anyone has had problems with their Edwards solar hot water system tank rusting and if anyone knows how much to replace the tank. Weighing up wether to change to gas instantaneous or rep are our 8 year old solar which had so many problems for previous owners. Thank you Re: Edwards hot water system problems 2Apr 25, 2013 3:01 pm With due respect to Homeone, it may pay to ask over at Whirlpool in the Green Tech forum where I believe there has been a lot of discussion on Edwards solar, some of it archived Arfur the sun master is the solar heating to "warm" the water in the tank the S26 is your hot water system which will heat the water (25 degrees?) so with both turned on you… 2 14076 instantaneous is three phase and draws heaps of current, the efficiency comes from not storing it so you don’t lose heat to the environment. The problem is it is not… 5 1671 I want to build a decking to the drawn shape outlined in black. The problem is how close can I build to the gas hot water unit? Will I be able to build around it and be… 0 20237 |
