thanks!
Land Fall - Send help!
thanks!
But usually that measurement is in meters which is why the builders you have spoken to are giving you the same answer.
Run a level string line from the back fence to the front and difference will be your fall.
(Excuse the mum & the dog, there's guys working on it at the moment otherwise I'd get a better pic, but I think you can see there's just no way its a 5m fall)
Thanks for your help
It’s obvious when looking at the top of the front retaining wall. Take the top of the wall as being 0 and anything above it is your fall.
Hard to tell from the photo but looks over 2 mtr fall.
The building area might have less of a fall.
By the way very nice block. If landscaped correctly it will look magnificent
Removing soil isn’t the expensive part, the rock removal, peiring, edge beams and additional concrete required to build the foundation is where the money gets spent. Plus factor in retaining walls if needed.
Without a soil test the price will be hard to determine.
Looking forward to seeing more pics.
I wouldn't be surprised at all for that to be 5m on a site survey.
This is my site - also 5m fall.
You just need to think about the design a little bit more and go with a split level design. Whilst it will add a retaining wall through the house and an extra set of steps - making the house follow the slope of the land will lead to a better design outcome.
Hope this helps.
Travis
4
Thank you Splashers. Tomorrow I might check if I can get a few packs of 300x300 in the same tile finish. It may be good to use these could in the shower recesses. I'm not…
11/11/2023
I've got a challenge here. Background is the builder has cut too deep for the slab and the slab is now below the very substantial retaining wall. It's failed occupancy…
23/04/2024
9
AS4654.2-2012 External Membranes it is "Informative" but if you get water ingress your insurance assessor will go to this straight away and if not achieved, they will deny…
