Browse Forums General Discussion 1 Apr 09, 2013 6:32 am I was wanting to put a strip of cement down in front of a stone wall - I am not sure what the technical name for this is (basically it stops the grass growing hard up against the wall). Are there any tips for how deep the cement needs to go? How do you make sure that it stays in a neat line? Re: Cement in front of a wall 2Apr 09, 2013 8:50 am Sounds like you mean a mowing strip. 70mm would be ample thickness and it would be kept 'in a straight line' by the edge-board used to box the concrete Arfur Re: Cement in front of a wall 3Apr 09, 2013 8:54 am So it 'forms' an edge .. ?? Where you are coming from is where you are going to... Hi, Currently building, we are on a sloping block so we have from floor level to the roof in axon cladding. Below floor level to the ground I want to put brick facings /… 0 4496 DIY, Home Maintenance & Repair All my inside walls are Fibre Cement & House has Steel frames... Tricky when one wants to hang pictures or do Wainscoating Paneling up the hallway. Those little nail… 0 3161 Thank you again Simeon.. I will call my certifier for that. Have a good day 4 5197 |
