Browse Forums General Discussion Re: Getting rid of musty smell in wardrobe 4Apr 12, 2013 5:16 pm Where you are coming from is where you are going to... Re: Getting rid of musty smell in wardrobe 6Apr 19, 2013 8:34 am Where you are coming from is where you are going to... Re: Getting rid of musty smell in wardrobe 8Apr 20, 2013 12:26 pm True enough - though the OP may not know there was dampness as per normal, most people are unaware of what makes the musky smell in the first place. Mostly it is dampness anyhoo they seem to have not required an answer Where you are coming from is where you are going to... Normally you use builders bog. Polyurethane painting is basically the same principle as car panel beating and painting. All the prep work is the same and so is the… 3 3077 Probably a not bad thing to mention particle board should in case anyone else reading this got the two confused. 6 4906 Use a product like Equisol's Vitalise to clean the deck then coat with a penetrating timber oil. It will look 10 years younger and add value to your home. Visit for… 1 15812 |
