Browse Forums General Discussion Re: Garden bed around house 2Apr 08, 2013 1:26 pm I think the concretors are just trying to get a bit more work for themselves My understanding is that you should try and keep the "climate" in the soil around your slab uniform in terms of the water balance. Never put soil or anything else (eg mulch) higher than the weepholes in the bricks (I'm assuming you have a brick home) and don't let water pool anywhere next to the slab. I was given a brochure with illustrations by my builder at handover which had some do's and don'ts of putting gardens around your home. Found this one online which seems to have some good advice http://www.avjennings.com.au/getfile/f9 ... ce__1.aspx Hope that helps Re: Garden bed around house 5Apr 08, 2013 7:20 pm When we built in Adelaide some years ago the builder's warranty stated unless there was perimeter concrete paving around the building, (forget the width) and grading away at etc etc; the home warranty could become void. I would check it out thoroughly rather than take advice. Arfur You’re on the right track, wire brush in a grinder then a zinc rich epoxy primer then a top coat of some sort, like a waterproofing membrane. Raising the concrete would… 1 4218 Thanks for the photos. You need to know whether the inflow or the overflow pipe is leaking and this is a simple process of elimination. INFLOW: The vertical riser… 4 3879 There is evidence of water on the head reveals. That could have happened during the build, or may be happening currently. There are water stains above a couple of windows… 2 2680 |
