Water hammer
From turning it on until about mid way the knocking/banging is continuous and sounds really bad.
Am wondering if this would be classed as acceptable or would be considered some kind of fault that should be attempted to be rectified.
Hopefully same does not apply inside although I can't see why it wouldn't..
Any thoughts??
Stewie
Thanks Stewie
1=instal hammer arrestors on hot and cold washing machine taps as these will be the worst when washing machine and dishwasher solenoid slams on and off
2=all taps that are left open=washing machine=dishwasher=cistern=the washers need to be replaced with spring loaded types to absorb vibration
thanks jim roundbathcompany
1
This certainly doesn't look good. I would be engaging with an independent inspector to have a look at this. As for the unscheduled site visits, most builders are quite…
19/07/2023
8
thanks Chippy, i hope they have applied sealer but i am doubt to be honest, so i am gonna do this job after handover.
23/07/2023
11
If you can calculate the reasonable charged head from let's say 100mm below the gutter to the top of where the vertical riser's horizontal discharge pipe will be, that…
