Browse Forums General Discussion Re: Clipsal Light Switch Saturn Range 2Mar 21, 2013 7:22 pm We have them and the electrician told us there were a few ways they could wire them up. Ours are: lights off blue led off. Lights on blue led on. You can have them the opposite way as well. You need to get the electrician back to fix it. Re: Clipsal Light Switch Saturn Range 4Mar 22, 2013 10:59 am Vess We have them and the electrician told us there were a few ways they could wire them up. Ours are: lights off blue led off. Lights on blue led on. You can have them the opposite way as well. You need to get the electrician back to fix it. Ours our the same......maybe check directly with clipsal to check what their standard should be. If standard is blue light should be on when the lights are on, then I can't see why your electrician should not fix it to operate as standard. Otherwise there is no point in having these switches if the blue light is not to be activated. Good luck, I hope you can get it sorted. We built the Wisdom Majestic 40 - moved in! Our blog - http://ourwisdommajestic40.blogspot.com.au/ Our H1 thread - viewtopic.php?t=54156 Re: Clipsal Light Switch Saturn Range 5Mar 22, 2013 11:39 am All below functions can be achieved depending on how you wire them. LED permanently on (neutral required) Switch on - LED on (neutral required) Switch off - LED on (neutral required) Switch off - LED on (no neutral required) This wiring diagram from clipsal should give you a better idea. http://www.clipsal.com.au/trade/__data/ ... 000581.pdf My Building Thread: viewtopic.php?f=31&t=62776 Any electricians here please help. 1) Will the Fan need separate switch to ON/OFF/Speed eventhough it comes with Remote 2) how about… 0 1169 Hi - thanks for your reply. Yes I think 'Ill go for whitish with very speckly bits rather than pure white something like this. PS was actually 2008 I built the… 2 11674 That was always going to be a challenge and a test of patience. Full marks to your mate. Did you discuss the wet area near the trampoline? 16 17325 |
