Browse Forums General Discussion 1 Mar 18, 2013 12:26 pm I recently purchased a property and intend to build on it in there near future. Have removed a few trees around the back e.t.c The problem i am faced with is i have this 3 trees blocking the view and were i intend to build the house. They are amongest alot of rocks. The house will be raised above the ground by the use of stumps. What i am worried about is the roots left over by the tree. Does anybody have any suggestion on how to remove these trees roots and all Thankyou Re: Tree Removal (Within Rocks) 3Mar 19, 2013 7:08 am Yeah they will be under the house, bloke from work said you should not cut them down yet. get something to pull them out with. They are easier to get leverage on still in. He has recently left work and I haven't been able to get in contact with him. Re: Tree Removal (Within Rocks) 4Mar 19, 2013 8:57 am You need to have the entire root ball removed. Easiest way is to cut the tree off about 4-6ft above the ground and have a drott snatch it out. There are restrictions on building over trees that have been ground out so do not do this! DIY, Home Maintenance & Repair At a bit of a loss on this one - we're thinking the original owners never removed the protective laminate covers from their kitchen cabinets after installation and in the… 0 6330 Hi, planning on using the attached stone pieces in my bathroom. I want to remove stains and gloss seal. Can I get some advice on best way to remove stains and best… 0 6709 PM me your email. I have a build excavation calculator you can use based on your plans to double check what your builder is telling you. Cheers Simeon 1 10236 |
