Browse Forums General Discussion 1 Mar 13, 2013 7:09 am Hoping someone out there has some advice about the best way of attaching a clothesline to a weatherboard house. Can you attach it direct to the weatherboards? Do you need packing? Or is it best to put in some upright posts against the house? Any pictures, tips would be appreciated. Re: Attaching a clothesline to weatherboards 2Mar 13, 2013 7:45 am Is the clothesline a fold down type or a pull out type? I've installed a fold down to weatherboards before, basically you need to attach it to the stud work if you can. When I installed ours the holes were about 60mm out to the studs so I fixed two treated pine 140 x 19 plates to the stud work and then attached the clothesline to the plates with coach bolts, hope that makes sense.. Re: Attaching a clothesline to weatherboards 3Mar 13, 2013 10:44 am Hi PaulMac, Thanks for you reply. Our clothesline is a fold down type, 2 metres wide and the weatherboards are featheredge. So using your system, you had no problems with the weight of the line? Re: Attaching a clothesline to weatherboards 4Mar 13, 2013 3:33 pm Liliana Hi PaulMac, Thanks for you reply. Our clothesline is a fold down type, 2 metres wide and the weatherboards are featheredge. So using your system, you had no problems with the weight of the line? No problems at all, you can do it a few different ways as long as you mount to the studs, either directly through the brackets on the clothesline or use a timber support mounted to the studs. How wide are the mounting holes at each end of the clothesline? DIY, Home Maintenance & Repair Follow up question - any ideas on how to set up a portable air conditioner through this kind of window? 1 6240 I plan on installing an undercover walkway (awning ??) from my carport to the back door as shown in sketch. I will be using Boxspan Beams and have no concerns regarding… 0 773 |
