Browse Forums General Discussion 1 Feb 27, 2013 5:53 pm Greetings; I am hoping to convert my Garage to a Bedroom / Study in QLD. it is a duplex that has a concrete floor, it is one of the old styles where the laundry and garage are in one. i have insulation in the room (that i installed myself) and i am getting the plans drawn up soon and running it though building certifier and draftsman. However i was wondering if there is any requirements to make it into a livable area ? Re: Renovating Garage to Bedroom 2Feb 28, 2013 9:57 am Part of the requirement would be that there needs to be a (plastic) membrane under the concrete. Peter Clarkson - AusDesign Australia www.ausdesign.com.au This information is intended to provide general information only. It does not purport to be a comprehensive advice. Re: Renovating Garage to Bedroom 3Feb 28, 2013 10:15 am also you are required to have windows that total area has to be 10% of the floor area and 5% to be able to be opened. Re: Renovating Garage to Bedroom 4Feb 28, 2013 11:51 am ausdesign Part of the requirement would be that there needs to be a (plastic) membrane under the concrete. yea, i read that somewhere, is there a way to find out if the plastic was put down when they built the house ? Re: Renovating Garage to Bedroom 5Feb 28, 2013 12:08 pm Quote: is there a way to find out if the plastic was put down when they built the house ? It will be difficult if you have perimeter paving, so I guess the next best thing will be a moisture meter during winter to see how much dampness permeates through the floor, which you may need to prove to Council Arfur Re: Renovating Garage to Bedroom 6Feb 28, 2013 12:25 pm yea, i was kinda hoping that they put it down when they built the houses. it is a duplex and the houses are built side to side. There are the two garages between the 2 duplexes and i am hoping when they put the plastic down that they just ran it the whole length from my nabs start to my end... What you are looking at is fibrous plaster, true gypsum, it is cast on horizontal beds with fibers included to give strength. I has no Asbestos in it. Houses before 1985… 2 7142 Personally, considering your layout (study/work desks in bedrooms), I don't think you have any other option but to leave NW windows and make them as big as possible e.g.… 7 10483 Hi, I'm planning to build a new house and wanted to get some feedback on the different window designs for a master bedroom. Our bedroom is north facing and the bed will… 0 4561 |
