Browse Forums General Discussion 1 Apr 18, 2008 3:40 pm I removed some skirting boards and seem to have inadvertently removed the paper coating of the plasterboard below. I now have a crumbly strip at the bottom of the wall where I want to reattach the skirting boards, but it looks too fragile. I thought to either remove and replace the pasterboard (seems rather difficult) or paint some adhesive type product over the exposed plaster.
Thanks Ian Re: Repair Plasterboard 2Apr 18, 2008 4:04 pm To patch it, cut the hole a little larger, get another piece of plaster and using plaster adhesive stick the piece in behind. Clamp it if you can. Then once that's dry, cut and glue a new piece in the hole. Taper the edge of the hole and plaster patch with a knife and use plaster to fill the hole around the edge. Sand , prime and paint.
Dunno if there's an adhesive you can spray or roll on. If the skirting will cover the hole, don't worry about fixing it. plaster drama - more info 3Apr 18, 2008 4:31 pm Thanks for the advice - its not actually a hole though. the entire section of paper under the skirting board has peeled off the plaster - leaving a strip of exposed plaster about 5cm x 4m. I need to replace the skirting boards but am concerned if I try to hammer anything into this it will just turn to dust. Re: Repair Plasterboard 4Apr 18, 2008 4:46 pm the skirt needs to be nailed to wood, not plaster.
Find the studs or the baseboard and nail to that! Re: Repair Plasterboard 5Apr 19, 2008 5:22 pm I meant cut out the partwith no paper on it and replace it. But 4m long.... ![]() As above, there will be a piece of timber along the base of the wall (roughly 2 inches high), that's what you nail skirting to. As long as you skirting covers it up you'll have no issue. Thank you alexp79 and gommeqld for your advice, that's very helpful, thanks 3 4394 2 10713 I have tried emailing them, hope the links work. I am so technologically deficient I am not not sure how to post them here, so if you are able to I would be happy for… 3 2204 ![]() |
