Browse Forums General Discussion 1 Feb 07, 2013 8:12 am Hi All, I'm in the very early stages of building on a sloping block, and I'm still trying to get my head around a few things. I'll be doing a mix of bearer and joist and slab. Can anyone tell me if it's the structural engineer or the builder who design the actual specs of the bearer and joist plan? ie size, position, spacing or bearers and joists. What about frame headers(lintels) above windows and doors, as well as bracing? Thanks in advance. Re: Does a structural engineer or builder do this? 2Feb 07, 2013 10:23 am There are design tables for a lot of these things Timber industry web sites are normally good for bearers and joists. If you are going for steel lintels the manufacturers should have design tables The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Does a structural engineer or builder do this? 3Feb 07, 2013 10:47 am bashworth There are design tables for a lot of these things Timber industry web sites are normally good for bearers and joists. If you are going for steel lintels the manufacturers should have design tables Thanks bashworth. So would the engineer or the builder usually be the one to consult the span tables and come up with the layout? Re: Does a structural engineer or builder do this? 5Mar 19, 2013 5:14 am I think it is fair to say most builders these days would cope without an engineer. We rarely use an engineer and we do a lot of this sort of work. My experience is with an engineer, the cost ends up higher. cheers The engineering is the engineering. It's irrelevant how much material you have. Unless it fits the requirements of your design the engineer can't "make"it work. You might… 7 9687 3 6403 |
