Browse Forums General Discussion 1 Jan 22, 2013 7:00 pm So I just have a quick question. Today our neighbour has poured concrete for paths around his house and we came home to fine much of it come through under our fence. Will they be able to clean this up or should I start getting annoyed now? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅
Re: Quick q- neighbours concrete spill into our property.. 2Jan 22, 2013 7:08 pm I'd act reasonably quickly. Re: Quick q- neighbours concrete spill into our property.. 4Jan 22, 2013 10:53 pm I would be annoyed... Hope you get it sorted! Jen Building with HomeGroupWA (started as Scott Park Homes ) - Grand Wisteria Check out my Build Thread!! Time line on P1. Re: Quick q- neighbours concrete spill into our property.. 5Jan 23, 2013 5:18 am The base of the fence will get full of dirt and vegitation over the next few years. I myself wouldn't worry about it too much unless it was a huge amount. Re: Quick q- neighbours concrete spill into our property.. 6Jan 23, 2013 6:38 am talk to your neighbors and show them what happened i would not try and make a big deal about of it as you will be living next door to the neighbor for a long time. and like Lourance alot of it will be covered up by dirt and vegetation. does some of it come off when you scrap at it? Re: Quick q- neighbours concrete spill into our property.. 7Jan 28, 2013 7:27 pm Most of that excess concrete would be stuck to the form work and it should come off once the concreters take their form work away. The only issue I would have is that they have formed up on your property, technically the boundary is down the middle of the fence.....the form work should be on their side....the concreter should have known that but by the image that you posted it looks like they have used an amature because its very messy and it hasn't been finished neatly. Re: Quick q- neighbours concrete spill into our property.. 8Jan 28, 2013 7:46 pm It looks like they have concreted the fence in, how would you remove a panel if you needed to? Our concreter said to leave a gap before the fence for water run off and any future fence maintanence/replacement. Re: Quick q- neighbours concrete spill into our property.. 9Jan 29, 2013 7:53 am sounds like the neighbour poured his own paths. no wonder there is no form work. Like said above I hate to think what will happen when a fencing panel needs replacement. His path is going to get chipped and broken to get it apart. 1. Roof cleaning and paint - which colour do you recommend? I often see black/ dark grey in use these days but I would prefer… 0 8334 it depends on the natural ground level, if they excavated their boundary wall needed to be built as a retaining wall. If you filled, which sounds like the case then you… 1 7095 The only thing to add to these comments is that where possible it's always good to try and work with people than just say "no" because you can. Having someone… 4 17155 |
