Browse Forums General Discussion 1 Jan 17, 2013 1:37 pm Hello all those that can help. Our Rheem solar hot water unit makes a very annoying pulsating buzzing noise originating from the control unit attached to the water tank. It varies in sound depending on the time of the day and usage. I am guessing that when the unit has been heating up all day and no hot water has been used for a while, the noise tends to be quite load. Right now for example the temp is 39c but I think the wife has been using the hot water (maybe, didn't ask) and therefore there is no buzzing. The Rheem plumber came by and said that the noise was normal and that the only solution was to put a timer on the GPO to turn the solar part off during different times of the day. I thought this might be logical but a major cope out from a Rheem product. I have read the reviews on productreview and it scores a low 1.5 star for the unit. Any thoughts from anyone or has anyone experienced what I mentioned? Re: Rheem solar hot water control unit making pulsating soun 2Feb 14, 2013 10:52 am A timer could be put on the GPO but it would go against purpose of the solar. Our advise would be to get back in touch with Rheem as it sounds like a faulty product. If you need any further advise please do not hesitate to contact us http://www.electricianstoday.com.au/contact/ Yes, Im following your Lindfield build, looks amazing. 4 1793 the sun master is the solar heating to "warm" the water in the tank the S26 is your hot water system which will heat the water (25 degrees?) so with both turned on you… 2 14414 I want to build a decking to the drawn shape outlined in black. The problem is how close can I build to the gas hot water unit? Will I be able to build around it and be… 0 20404 |
