Browse Forums General Discussion 1 Jan 14, 2013 1:43 pm I have just bought a camper trailer and am looking to convert my side fence & small access gate into 2 access gates & park the trailer behind it. My question is, is it possible to convert the fence part into a swinging gate and keep the existing gate (this having 2 swinging gates to allow the trailer to be parked behind & secure)? See pic for configuration. Wondering if it is worth the effort or to just buy a gate to fit - keeping in mind I am trying to keep the costs to the bare minimum! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Convert fence into a gate - possible? 2Jan 14, 2013 2:25 pm Depends on how much of a handyman you are I think. You would need to add a frame to the re-used fence section to support the hinges and help it support it's own weight, probably upgrade the post the hinges attach to. It would also depend if you want to colour-match the new frame or if you don't mind using whatever you can get. If you re not going to be opening it very often, perhaps converting it to a removable fence panel might be cheaper? Using bolts of some sort to attach to fence and a drop-in boot inset into the ground for the post - it might take you a half a minute to undo and remove the panel instead of 5 seconds to swing the gate when you want to move the trailor through, but it might also be a cheaper/easier conversion right now. Land settled May '14. Building the PD Hoffman39: 5/11=site start, 13/11=slab pour, 26/11=frame complete, 10/12=roof on, 12/12=bricking started. Blog: http://jyndeira.net/blog/ Re: Convert fence into a gate - possible? 3Jan 14, 2013 5:58 pm The problems I can see with the above suggestion is how to make it lockable/secure pending any future insurance claim, should your trailer ever get pinched. I would contact a gate specialists in your area and get some quotes for a professional job that will last, something you will be happy with and doesn't look like a dog's dinner Arfur DIY, Home Maintenance & Repair I mean, I install them/sell them for a living so I haven't done DIY, unless you count the first one I installed lol. (electrician by trade). Usually a 6-8 hour job for… 3 41545 consider putting in wall WC instead of robe in the same bedroom, then it might be doable to hook up to the existing piping. 4 6628 I should have followed up on this thread. So, the pier foundation wasn't large enough on the side it was leaning towards, and the NBN cable went through the pier, just… 8 12127 |
