Saw this on grand designs au, and looks like a great idea to store water under your house!
just wondering if anyone else had done this? would it require more concrete for the slab or less?
http://www.remtec.net.au/aquacomb.html
Browse Forums General Discussion 1 Jan 12, 2013 9:45 am Saw this on grand designs au, and looks like a great idea to store water under your house! just wondering if anyone else had done this? would it require more concrete for the slab or less? http://www.remtec.net.au/aquacomb.html 2nd-Fix | Blog Building with Desyn Homes previously with the insolvent [url=https://www.facebook.com/7NewsAdelaide/videos/1162546323776021/]Endeavour Homes[/url] Re: Under-Slab RWT 2Jan 12, 2013 12:36 pm Maybe OK but as with all things what do you do when maintenance on it is needed. You would in effect need twice the slab to support the house over that tank or at least pretty big footings and dwarf masonry walls. We are looking to put a 23,000L tank in our house when we do our big build this year but will sacrifice a small room to have a built in tank instead. We both hate the look of external tanks and to get something this big we would lose a good part of our back yard. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Probably a thick concrete slab then reinforced 300mm besser block walls and waterproofing, then a concrete slab lid with an access hatch. Stewie Re: Under-Slab RWT 3Jan 12, 2013 6:30 pm Stewie D Probably a thick concrete slab then reinforced 300mm besser block walls and waterproofing, then a concrete slab lid with an access hatch. Stewie yeah thats a good idea, and you'd want it defiantly reinforced, id hate to see where 23ton of water is gonna good if the tank leaks! i just figured they could use them instead of waffle pods under the slab 2nd-Fix | Blog Building with Desyn Homes previously with the insolvent [url=https://www.facebook.com/7NewsAdelaide/videos/1162546323776021/]Endeavour Homes[/url] Re: Under-Slab RWT 4Jan 14, 2013 8:40 am Maybe FF but the extra costs to strengthen the slab and then finding a builder willing to build it could cause problems I'd imagine. I like the idea though and would give people who don't have the room for an above ground tank another option. It is similar to the bladder tanks used under decks etc. Stewie Thanks for the insights, that makes perfect sense, and yeah, I will be leaning on the experience of the excavator operator entirely. 6 16142 4 5114 |
