Browse Forums General Discussion Re: URBAN MYTHS .... ? 201Dec 20, 2015 12:28 am Winter concrete may contain more accelerant in the mix to help it set sooner. But there's no quality control or standardizing of mixes which is the real issue here. Re: URBAN MYTHS .... ? 202Dec 20, 2015 6:46 am Treeseachanger Winter concrete may contain more accelerant in the mix to help it set sooner. But there's no quality control or standardizing of mixes which is the real issue here. TSC - so ... you're supporting the theory ... Re: URBAN MYTHS .... ? 203Dec 20, 2015 9:05 am Quote: Winter concrete may contain more accelerant in the mix to help it set sooner. But there's no quality control or standardizing of mixes which is the real issue here. A lot of the drawings that we worked to in the past specified the usual specs for concrete like mPa etc and definitely had a disclaimer that no additives were to be added to the mix pre-pour without authorisation from the engineer. Stewie Re: URBAN MYTHS .... ? 204Dec 20, 2015 3:00 pm Stewie D Quote: Winter concrete may contain more accelerant in the mix to help it set sooner. But there's no quality control or standardizing of mixes which is the real issue here. A lot of the drawings that we worked to in the past specified the usual specs for concrete like mPa etc and definitely had a disclaimer that no additives were to be added to the mix pre-pour without authorisation from the engineer. Stewie I would think the batch plant would do what they feel without authorisation Re: URBAN MYTHS .... ? 206Dec 20, 2015 8:10 pm Stewie D Maybe that's how you do it in WA but in Sydney they wouldn't have a job supplying concrete to the construction industry for very long. Stewie I'm referring to residential. Just like the extra squirts of water when they get to site. Commercial sites usually get test cylinders and batch dockets Re: URBAN MYTHS .... ? 207Dec 23, 2015 7:01 am Next door has the slab and woodwork - but no roof. Might be leaving it till January ... Is this a good thing - some say you need to leave the slab for longer. Re: URBAN MYTHS .... ? 208Dec 23, 2015 7:28 am Pouring footings and slabs for residential jobs our engineer wanted to see copies of those dockets as well just to make sure of the strength. Even for our small jobs he had the standard blurb I mentioned above regarding additives which would just be standard general comments in his specs for any job large or small. Stewie Re: URBAN MYTHS .... ? 209Feb 27, 2016 6:45 am Slightly off the point - but so many "sensible otherwise" people repost those adverts about wonderful prizes if you repost the advert - eg fly around the world 50 times - first class - if you repost etc. Shares in some major company - or money if you repost. WHY do they do it - are we that greedy/needy/gullible ? Do we live on hope to that degree ? However - if you reply to this post you may win something ... Re: URBAN MYTHS .... ? 210May 06, 2016 10:57 am I've always been told to make a lot of noise when working out the back of our place - in a bushy type area. This - supposedly - scares away the snakes. Now - I haven't seen a snake for a while - since houses were built either side of us - but the back is still open - to the golf course. We have a bushy area and a water lagoon/trap. So can snakes hear - or do they just feel vibration ? They do have an inner ear - but this doesn't really hear. So - when in the bush - if you thump the ground you may have more affect on a snake than just making noise. Re: URBAN MYTHS .... ? 211Jan 14, 2017 11:18 am My favourite thread ... Do dogs with big paws grow larger because they have big paws ? My new Goldie has big paws and everyone makes this comment. Yet I think he'll just be normal size. Re: URBAN MYTHS .... ? 212Jan 15, 2017 8:16 am Many myths around why a 2x4 is not 2x4 ... Has anyone actually bought some lumber and thought it was ? . Re: URBAN MYTHS .... ? 214Jan 30, 2017 9:18 pm I've always been curious about the pool question !! another one that has always bugged me is that you can light a fart on fire lol, ive never seen it happen and seen people attempt any times with no success Re: URBAN MYTHS .... ? 215Jan 31, 2017 7:33 am I must admit I've never seen in this in the flesh - so to speak. Not sure why someone would try - perhaps alcohol ... Re: URBAN MYTHS .... ? 216Jan 31, 2017 9:57 am modcert ive never seen it happen Try You Tube. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: URBAN MYTHS .... ? 217Jan 31, 2017 11:53 am Will do - where would we be without Utube and Google ... Re: URBAN MYTHS .... ? 218Feb 03, 2017 5:22 pm I know we've all heard the one about the fibre glass pool "popping" out of the ground - a friend of a friend ... But - I heard an adaptation of it today - an underground water tank that "popped" out of the ground because it had been very dry and it was almost empty. I'm currently chasing it up - ie who the friend of a friend was - where they live etc etc. Probably as crazy as the pool myth ! Re: URBAN MYTHS .... ? 220Feb 05, 2017 10:39 am Agree - water "could" do it - if it was empty. And the water surrounded it. Clearly it would float if closed and in sufficient water. As a boat floats. Presumably if it was surrounded by water there would be water in it too ? |
