Browse Forums General Discussion 1 Jan 02, 2013 1:31 am Has anyone used the Lockwood Symmetry cavity passage set with retractable door pull - whatever this is? See http://www.lockweb.com.au/en/site/lockw ... ductId=937 I was thinking of just using the flush pull handles, but am interested to hear about anyone's experience of this more complicated door furniture - many thanks Re: Cavity sliding door furniture 3Jan 02, 2013 2:58 am Suprisingly, this type of furniture is not much different to a normal door handle install. If your after a lockable key set, then this is the system to use. You can get a passage set for general passage operation. This handle features a turn handle both sides of the door, same as you would have on a normal passage or bedroom door. But if it's just a privacy set you need to an en suite for example, your handle will have a turn handle on the inside, with an emergency release on the outside. The strike plate on privacy set is recessed back with a lip and the barrel for the lock will hook over the lip to lock the door. Hope this helps. 2 I’m in a similar position except I’m after sliding 3 stacking doors. I am on a second-story apartment of which the balcony would not adequately fit any bi-fold or… 5 16153 DIY, Home Maintenance & Repair Thanks Chippy . Did also see a YouTube video before. Removed them . Thanks again for the advice. 2 13960 |
