Browse Forums General Discussion 1 Dec 27, 2012 5:38 pm Hoping I am posting this in the right section... We are a bit confused at present with the location our downpipes have been installed with regards to the drains to soakwells - see pics Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hoping someone can explain this??? There also appears to be a couple of downpipes around the house with no drain below/near it. Anyone??? Building the Riva by Dale Alcock Homes. Follow our progress here: https://forum.homeone.com.au/viewtopic.php?t=57075 Re: Downpipes and drains Q 2Dec 27, 2012 6:21 pm Ours is the same it seems the roof plumber can put the down pipes where he wants be interesting to see if the soak well pipes get moved. PPA 30/6/12, Land 28/06/12, Contract 7/9/12, Valuation 11/9/12, Prestart 13/9/12, Settlement 18/10/12, Building Permit Issued 18/10/12, Footings 30/10/11, Slab 31/10/11 Re: Downpipes and drains Q 3Dec 27, 2012 6:27 pm Yeah, we thought maybe they will cut down the soakwell pipes right under ground level and run another pipe up to under the downpipes??? Seems pretty silly when your talking 12 inches, why wouldn't the plumber just put the downpipe above the drain??? Building the Riva by Dale Alcock Homes. Follow our progress here: https://forum.homeone.com.au/viewtopic.php?t=57075 Re: Downpipes and drains Q 4Dec 27, 2012 8:06 pm Beware-Water discharge near house foundation is never a good idea and the dampness will create conditions suitable for termite infestation. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Downpipes and drains Q 6Dec 27, 2012 8:57 pm Downpipes are installed at the gutter's low point. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Downpipes and drains Q 7Dec 27, 2012 9:32 pm So how exactly will the downpipes connect to the soakwell plumbing?? Anyone??? Building the Riva by Dale Alcock Homes. Follow our progress here: https://forum.homeone.com.au/viewtopic.php?t=57075 Re: Downpipes and drains Q 9Dec 29, 2012 6:22 pm who installed the soakwells? Were they done before the downpipes? if you did you will have to move them or repipe. If they did and you have it in contract that they will connect them to your downpipes then they will have to sort it out. Did you pay for a soakwell for every downpipe? Check your contract/agreement. Re: Downpipes and drains Q 10Dec 29, 2012 10:07 pm Pretty sure there are pipe connector things that connect soakwell to downpipe. It should meet together level with the ground. As in, you shouldn't see the pipes, you should only see the downpipe going straight into the ground, if that makes sense. If you did soakwells yourself, you'll just have to buy the connector things. By the way I'm no expert, this is just what I've figured out from looking at heaps of diagrams and stuff. GOODLIFE - Bravo - BUTLER http://getmistyfied.blogspot.com.au Display 20/02/2012 PPA 01/04/12 Prestart: 25/07/12 Settlement: 31/07/2012 Contracts:August Slab 19/11/12 BRICKS 10/11/12 Roof 16/01/13 Re: Downpipes and drains Q 11Dec 29, 2012 11:35 pm No we had nothing to do with it, it was all the builder - soakwells, storm water pipes and obviously the downpipes so it really shouldn't be our problem. All downpipes are to be connected to 3 soakwells (the big 1200mm concrete ones). Guess we will have to wait and see what they do, it just seems a bit nonsensical to put a drain pipe in one spot and then a downpipe a foot and a half away and then have to connect them up. :/ Building the Riva by Dale Alcock Homes. Follow our progress here: https://forum.homeone.com.au/viewtopic.php?t=57075 Re: Downpipes and drains Q 12Dec 30, 2012 9:36 am Looks like some one didn't follow the building plans then. So either the roof plumber or the person who dug the siakwells. Though usually the plumber follows the plans pretty closely some times they have to move a downpipe slightly from plan position it's usually not much at all. 2 Re: Downpipes and drains Q 13May 29, 2013 10:08 am Downpipe location is a complex thing. We usually leave this to the licensed roof plumber who has to do it right and issue a certificate of compliance. Then, after, the other work is done to match the location of the pops. This is the spot on the gutter for downpipe attachement. It is a cart before the horse. Actually happened not long ago to me. We were doing a lock-up job and the owner got a bit ahead of themselves. Just not understanding the way it works and not reading the plans. Can be fixed. Re: Downpipes and drains Q 14May 29, 2013 4:39 pm I disagree Building design is art, skill and a profession. This is why architects do degrees and architectural draftsperson diplomas. That is so they know what they are doing, to make sure building elements are correctly specified and fitted. Just as your house has to fit on the block so should every element be designed for functionality and appearance. Then the builder has to follow the plans and specifications. That is why roof is designed from the top down, gutters sized, downpipes positioned and drainage laid out. So why leave it to the plumber? The only explanation I have is that the builders are using unqualified and incompetent designers and I have seen plenty of evidence of that. If a draftie does not know where to put downpipes and brickwork articulation joints (they are supposed to know the regulations) what is he getting paid for? Please enlighten me otherwise. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Devkop The good news it is super easy to fix. Just get your plumber to divert it to the other side of the window. But for those people who are wondering what the… 2 1722 I recently went through a similar renovation and move scenario when updating our family home. We also swapped some rooms around and tackled a major… 2 10049 The HIA contract, in the term & conditions section states that "Commencment" is deemed when the drainage is started or the piers are dug or the slab is formed up (incase… 2 6182 |
