Browse Forums General Discussion 1 Dec 23, 2012 5:51 pm I'm not sure if this is the right place for this: I was wondering if anyone could help with some advice on buying a new hot water service for an existing build. My hot water service seems to have breathed its last. It's an old Rheem gas storage system in a cupboard in the laundry. Cupboard is 580w X 650d. The options I've been given are an outdoor continuous system - although there may be issues with where to put it: the best option wall is mostly window and very little wall. It's also very exposed to strong nor'easterly winds and I don't know if that's a problem for any of these systems. The only other option is a replacement storage system. Solar is beyond the budget and would need strata approval. Does anyone have any recommendations for small gas storage systems either indoor or outdoor? I live in coastal NSW. Outside temp sometimes gets down to zero in winter overnight and the water is a bit limey but otherwise good, I think... Re: New gas hot water service :@ 2Dec 25, 2012 10:26 am Continuous flow or Instantaneous are in my opinion far better and cheaper to run (I have one) but do require to be (from memory) 1.5m from opening doors and windows, so with limited wall-space you may have to go with another storage unit. Look online at manufacturers websites for dimensions and capacities, or you could call your local licensed plumber for a quote Arfur Re: New gas hot water service :@ 3Dec 25, 2012 2:14 pm Thanks for that. Will keep looking around at all the available options. Have found an indoor continuous system by Rinnai. Will ask my plumber if the area occupied by my existing system would be adaptable. I want to build a decking to the drawn shape outlined in black. The problem is how close can I build to the gas hot water unit? Will I be able to build around it and be… 0 20237 the sun master is the solar heating to "warm" the water in the tank the S26 is your hot water system which will heat the water (25 degrees?) so with both turned on you… 2 14076 DIY, Home Maintenance & Repair Hi, I've got a brand new (2nd hand) Bosch Hydropower 16H tankless hot water heater. Since it was installed I have noticed it leaks a lot. I took the cover off and it looks… 0 24149 |
