Browse Forums General Discussion 1 Oct 29, 2012 7:16 pm Hi, I was hoping somebody can help me out please. I have a roof which is badly covered in a green matter build up and there is also lots of mortar coming away from the top points. The roof tiles I have are called Whitelaw. I have had a roofing company look at the roof and they say they only install new roofs. They did say that the roof was beyond roof restoration and needed to be replaced. Can these kinds of roof tiles have a roof restoration done to them? My roof is only about 30 years old. If so, are there any good roof restoration companies in Melbourne that I can contact? Thanks in advance, Dave M Re: Roof restoration or roof replacement 2Oct 30, 2012 5:11 am If the tiles are not cracked or fretting ( slowly crumbling as the clay or concrete breaks down ) then it may simply need a good spray with a water blaster to remove any lichen, dirt or other crap and repointing of the hips and ridges. I'd certainly get a few other roof companies to look at it. And if any of the tiles are cracked, just turf them and replace with new ones. Stewie Re: Roof restoration or roof replacement 3Oct 30, 2012 6:12 pm Hi Dave, firstly the matter have on your roofing is called Lichen. The mortar / cement you have falling out is deteriorating away from the ‘ridge capping’. Your valley’s and gables are probably in the same condition if you have some of them on your roof. Unfortunately Dave, different companies will tell you stories about what you really require in order to suit themselves and the kind the service they offer. Companies in the new roofing game will only push new roofs. These companies also tend to (not all of them though) talk ill of roof restorations, saying that roof restorations are not worth doing. Well the above statement could not be further from the truth. Especially taking into account your roof tiles. They are a good product (Whitelaw) and only 30 years old. They are a prime candidate for a roof restoration. I think you should have a reputable roof restoration company inspect your roof. One who replaces roofs and also restores them. Then you will get an unbiased opinion of how to proceed. Offcourse our tradesmen are fully qualified in roof restorations and also roof replacements / new roof installs. So we pride ourselves on offering the correct advice on which option to choose. If you would like to give our team a buzz, we always available to answer any questions you may have. My advice is to make sure you have at least one reputable roof restoration company view your roof to make sure it can be restored. Don’t get pushed into something more expensive that may not need to done. Good luck with your decision. Phil. www.melbourneroofingrestorations.com.au Re: Roof restoration or roof replacement 4Apr 22, 2013 5:45 pm To the guys at Guardian Roofing. Thanks for all your help with my roofing. After procrastinating and then finally contacting you guys via this fantastic forum, my roof didn't need replacing after all. What a result with the roof painting. Not sure if I'm allowed to promote businesses here, but these guys were fantastic. Thanks again Phil and all the guys at guardian roofing. I will try and post some before and afters. Hi I bought an old cupboard that is in desperate need of some TLC. I was seeking some advice as to the best product to use to give it an oil but also bring it to life a… 0 3439 No the fireplace doesn’t work. It’s been enclosed. I’m not sure what was removed, as it was done quite some time ago - well before what I can see with photos online… 2 11584 We're looking at replacing the roof of a heritage listed home so it needs to be terracotta tiles, wondering if anyone has any recommendations, hints or… 0 1380 |
