Browse Forums General Discussion Re: Cost of Slab and DRIVEWAY 2Sep 11, 2006 11:59 am Hanibal,
Not all slabs are created equal! It will depend on how thick the slab is, type of reinforcement used, depth/width of footings, use of cantilevered footings, piering, etc, etc. Short answer, cannot be priced without seeing engineer's drawings. Re: driveway, again depends on lots of things - gradient of drive, thickness, reinforcement, edge thickening, loadings, drainage, etc. Roughly though, you are looking at about $75/m2 inc. GST for a 150mm thick road with SL72 mesh. Hi All Im laying a new slab on top of the old slab in the picture below, I have chipped away the tiles… 0 2950 Firstly the ableflex that has been installed needs (manufactures specification) a sealant cap over the top, preventing water draining down between the slab and the… 3 2527 ![]() custom probably not. Volume, most defiantly, but spec would vary. If youre doing a knock down, there additional costs associated with that that will eat into your budget… 1 1431 |
