Browse Forums General Discussion 1 Apr 02, 2008 5:23 am Hi,
We are considering building a house in Victoria with one the following builders: - Simonds Homes - National Builders Group - Henle Properties (the forum blocks the name of the builder you should add a 'y' after Henle) - Metrico (also gets blocked, add a 'n' after Metrico) Has anybody already built a house with one of these groups? What were your experiences, quality, price, service,...? Thanks Re: Builder experiences 2Apr 02, 2008 2:14 pm Welcome to the forum xiquan,
Make the search option your best friend...do a search on each of the builders you have mentioned, there should be lots of threads for you to read. We are building with H3nley so check our blog if you want to read about our experience. Re: Builder experiences 3Apr 03, 2008 12:24 pm Check out this web https://forum.homeone.com.au/viewtopic.php?t=1522
there are many blogs that you can see - which builder? which model? the construction progress? that people have chosen. You will get a better ideas. You have mandatory building inspections and privately engaged building inspections. The difference between the two comes down to inspecting the building so it's safe and… 3 18069 Hi Mofflepop, I would recommend finding a building designer to prepare plans, they should design to your specified budget. The benefit is you can tender the project out… 9 20417 |
