Browse Forums General Discussion 1 Sep 30, 2012 7:09 pm Im looking at putting in a garden shed 3.0m W x 2.2m D x 2.04m H and am wondering what is the min distance I can build it from the fence? As its under 10m2 I don't need council permits and being under 2.4m high I can build within the usual 1m setback but how close can I go?? Re: Garden shed min distance to boundary (VIC) 2Oct 01, 2012 10:16 am A phone call to your council's building services would answer your question. But pretty much (depending on your council), because your structure is under 10m2 and not made of brick, it does not fall under the building regulations and therefore you can put it anywhere you want. Once again, check with your council. Found the answer. The recommended distance is .... 1 6066 Is it possible to render an old corrugated iron shed.I have heard that it can be done if it is covered with chicken wire first.Not sure of the ratio of the render mix and… 0 4968 Thanks. Yeh ideally that would have been good, but have progressed too far now. Hoping some well placed internal walls fixed up into the battens will provide some… 2 5527 |
