Browse Forums General Discussion 1 Sep 07, 2012 12:19 pm I am interested in using Durra panels for my internal walls instead of plasterboard. Durra panels (from http://www.ortech.com.au/durra-panel ) are 5cm thick compressed straw panels. Compared to conventional plasterboard they are stronger, more insulative (sound & thermal) and extremely low, even negative on embodied energy scale since they are made from a waste product that is usually burnt in the field. Once installed & painted they look the same. Main drawback I can see is that they are thicker so we lose some floor space. 2 questions: 1) has anybody used them - and how did go? Has anybody considered them & decided against - for what reasons? 2) What does normal plasterboard cost per square metre - material only / installed? The Durra panel costs about $28/m2 supply only, but I don't think that includes the brackets you use to hold them top & bottom. Re: plasterboard vs Durra panels for internal walls 2Jan 02, 2021 8:20 am Bump... did you end up using the durra panels? I'm considering them for my build and would love to know how you found them? We officially own some dirt!! and a little grass... Thank you alexp79 and gommeqld for your advice, that's very helpful, thanks 3 7935 What we have done in a few theatres ( including my own) is run 2 layers of 13mm gyprock, but sounds insulation especially for the bass is really tricky as a lot of that… 4 2568 Plasterboard Gyprock is very popular as a reveal liner these days. You need to provide a way of supporting it, we use a modified timber reveal or bracket. You will be… 1 4748 |
