Got home 2 nights ago and after the rain to find a pool of water in the middle of my garage. I had suspected it came through the garage wall adjacent to a neighbour's garden and last night, from the water flow, I can confirm that it is actually coming through the wall side. My house was just built less than 2 years. Is there anything I can do to seal off the leak and do I contact the neighbour or builder about it.
Any advice appreciated. Ta
Water leaking into Garage from neighbours garden
All new home builds now in victoria require this as a standard part of a new buidling.
Hi, I've got a brand new (2nd hand) Bosch Hydropower 16H tankless hot water heater. Since it was installed I have noticed it leaks a lot. I took the cover off and it looks…
5/04/2024
7
Thanks for your advice. So far i have not noticed any issues with doors and windows. Builder advised they will organise drainers to inspect 2 weeks ago but no further…
13/06/2023
1
it depends on the natural ground level, if they excavated their boundary wall needed to be built as a retaining wall. If you filled, which sounds like the case then you…
