Browse Forums General Discussion Re: Cost of 600mm centre Trusses VS 900mm centres 3Aug 15, 2012 9:19 am Settlement 1/2/12 New Shed 23/3/12 Slab poured 27/3/12 Frame complete 4/5/12 Roof complete 1/6/12 LOCKUP 29/6/12 Our new build blog http://kareenhillsownerbuild.blogspot.com/ Re: Cost of 600mm centre Trusses VS 900mm centres 9Aug 15, 2012 8:54 pm Settlement 1/2/12 New Shed 23/3/12 Slab poured 27/3/12 Frame complete 4/5/12 Roof complete 1/6/12 LOCKUP 29/6/12 Our new build blog http://kareenhillsownerbuild.blogspot.com/ Re: Cost of 600mm centre Trusses VS 900mm centres 10Aug 15, 2012 10:30 pm We used to put the trusses at 1200 centers then batten the ceiling with furring channel. The only problem ever encountered was the 4' gap between them made it hard for short arses like myself. 900 centers and furring channel will give you a better finished ceiling than 600 centers with the sheets screwed straight to the truss. My daughter and son in law are about to start building, they are having a 600mm induction cook top and 900mm oven. It's personal preferance 5 10977 Versaloc is a mortarless besser block system that still needs a properly engineered footing. If you just do a 400x200 footing it will fail in time. At 17m long you need it… 1 18397 |
